Wheels for 1966 B-body with ’66 A-body 8 3/4
EmilFrimodig
11:18 AM
Hi! I have a 1966 Coronet with a ’66 Dart 8 3/4 with some hideously large bolt on spacers, are there any wheel suggestions for this without using spacers?
Best regards
Sounds like an innocent question. With a shitload of variables
But the innocent answer would be, measure everything- and get custom wheels made to the specs.
Best solution. Sell the A body rear for big money. Buy a correct B body rear axle.
Then everything fits properly, and some abody guy gets a rear end.
What bolt pattern is the A-body rear? Are you sure the spacers are not pattern changers? (Im betting they are really adapters, not spacers)
A correct b-body rear could probably be purchased and have money left over after selling the a-body rear, or...
Custom backspace wheels could solve the problem.
One solution could end up with money in your pocket, the other could run $1000/pair.
(The last custom wheels I bought, 15x12 with minimum b.s. cost me $800, seven years ago)
Yeah, you’re right! They are pattern changers! My thought was switching drive axles in it to 5x4,5..
Will take some photos
No need.
Follow the advice as given. The A body 8 3/4" axle as is could sell for 3 times the price of a stock B body 8 3/4" axle.
Why?
90% of the A body cars were fitted with the weak 7 1/4" axle so when people fix up their cars and increase the power, they need a stronger axle that will hold together. BOOM, that is where YOU come in.
The reason that the A body axle is worth three times as much as a B body axle is simple: Availability. The B body axle is far more common.
I just sold an A body 8 3/4" axle for $1200. A B body axle can be bought for well under $500. I sold one a few years back for $250, complete from drum to drum.
This is free money for you, man!
