When to grease suspension?
westie47
8:51 PM
Abbotsford, BC
When should I grease the ball joints, tie rod ends, etc? Does it matter if I grease them before everything is torqued or wheel alignment is done?
Grease Everything before it is Rolled, Steered, driven or trailered.
Before any suspension movement. They move a lot on a trailer.
Great, thanks for the advice!
when I put everything together, I torqued all the fittings to factory specs but then couldn’t move the suspension so I loosened everything off and no problems...
