Where to get Correct fitting brake drums for 69 Super Bee?
SCATPACK1
7:38 PM
TN
Like the header says, who or where can you order the correct front brake drums for a 69 Super Bee w 4-speed. Ones I have looked hat have the wrong size center register. Too big for the hub. My Bee has 383 and 4 speed. Number on left front is L-35924-9. Not sure what size it is as I have not measured it yet. But some of the brainacs on here will know the correct size from the part number. TIA
When you measure them , you will find out that they ARE 11 " x 3 " , but they will measure 11 " x 3 1/4 " actual Drum depth --- but keep in mind that the Brake Shoe does not go lip - to - lip, they are centered and have an 1 / 8 " th of an inch on either side.
So, the Brake Drums are named , as per the Brake Shoe width , both of which will be 11 " x 3 ".....
And the Great News is, I have *** N.O.S. *** U.S.A. made *** 11 " x 3 " Front Brake Drums !!! , *** N.O.S. *** U.S.A. made ***
Front Asbestos Brake Shoes, the softest, smooooooothest braking system known to mankind, wheel cylinders, brake hardware,
Front Inner and Outer Bearings and Seals, and much much more......
P.M. me, as per forum rules, if interested..... Yours, Craig.......
