Vanderstel
Take note of the wheels.
I don't know what it means?
I think it means he will be buying new tires a lot oftener than us.
In some crowds, that "Look" is called Stanced.
In other words, the car has a specific Stance. That extreme negative camber is not a simple adjustment either. You have to really modify the mounting points of the suspension to get that look.
Hey...I think it looks dumb as **** like most of you do BUT....
Who remembers this look?
In retrospect, the high *** end looks stupid too. How about THIS look ??
That's all it is, right there - common attention whoring.I'll translate for you - it means "Look at meeeeee!!!"
I agree with this, except the bottom car has too much rim by far and not enough fat rubber. 2" less rim diameter at least. Old cars should not have low profile rims, but it's not my car so people should do what they like.A certain amount of negative camber helps with cornering grip because the outer tires in a turn will be closer to upright when the body leans.
The "stanced" cars took that to the extreme.
A jacked up car with N-50-15" tires handled poorly.
I am not interested in poor handling cars no matter how fast they are in a straight line.
I have long preferred the look of a NASCAR inspired street car that looks like the car is lowered over wide tires that fill the wheelwells out nicely:
