themechanic
Oklahoma is OK
- 7:36 AM
- Nov 11, 2012
- Moore, Oklahoma
I use valve grinding compound.The rubber band stripped screw removal trick is great - thanks for that!
I use the square drives all the time....Philips screws are for the home handyman with only two screwdrivers in his arsenal..... rusty and blunt.We have square drive Robertson screws here in Canada. Used mostly in construction and furniture. More positive than Phillips.
Like previously mentioned, US and imported Phillips are different.Interesting. I’ve noticed that some Phillips head screws handle the torque way better than others I always figured the the El Strippos were from China.
except for the guys who don't realize the bits wear out and sounds like a god dmn beaver working away,that sends me! I once worked with a guy that said the drives were for removing them, he just pounded them deck screws in!I use the square drives all the time....Philips screws are for the home handyman with only two screwdrivers in his arsenal..... rusty and blunt.
Note I said 'arsenal' ..... re-read that please.
I find that even the Pozi screws are not that good..... the best by far are square drive - or Robertson as they are known in Canada.
Slotted screws are reserved for Dinosaurs who can't handle change.
