windows leaking and not fitting good- help
Pa's Sat
6:13 AM
Hickman
After the restore was finished, the wind noise is very bad. The top rail has all new rubber seals. I am looking for the window channels and the fuzzie rails at the side of windows. Have not found anyplace that has them. If they are out there I am sure some one here will know. Thanks for the help!
Check out our forum Captain Kirk, Joe Suchy. He has a lot of parts and bought several from him. Reckon you know how the windows can be adjusted for & aft and inward/outward. Dumb inquiry maybe...just sayin...
dont get too upset , they didnt fit/seal/work all that well when brand new !!
Had to replace the vent window and in learning how it all apart the front channel plastic got damaged (it split in halve) so need to replace it. Window is back in so can go for drives again. Yes it always had some wind noise.
