SOLD Z Bar 66-70 BB/SB 71-74 SB Torque Shaft
Part Stalker
11:20 PM
East of Tacoma
Feedback: +52 / =0 / -0
Found this in a milk crate and will probably never need it. Appears to be in typical good used shape. Use as is or detail it to suit your needs. The below information is from Brewers website that gives more of its compatibility. I would like $50 plus shipping from Puyallup WA.
Torque Shaft, fits big or small block 1966-79 B-body, small block 1970-74 E-body & 1971-74 B-body applications. Also works in 1970 & later B/E-body cars when using earlier 11" cast iron or Lakewood bellhousing (tube usually needs shortened on bellhousing end with Lakewood bellhousing) & 1975-9 Chrysler Cordoba, 1975-8 Plymouth Sport Fury, 1977-8 Dodge Monaco, 1978-9 Dodge Magnum & 1979 Chrysler 300, 9" tube length, lower offset adjuster arm welded 1 1/4" from end of tube, uses our AK449 adjusting rod kit. Reference OE part numbers 2534 538 and 2950 914
