Whats the best mechanical fan
69clone
4:50 AM
Tennessee
I'm wondering what the best mechanical fan to run on my car will be? My original 5 blade is too deep for my liking. I have a 7 blade fan off my dart that is thinner but it isn't for a clutch setup..
So before I go buying a OEM 7 blade clutch fan I was wonder if you guys recommend anything else? I see flex a lite and some other companies make solid steel fans too. I just don't want something to grenade on me.. I already destroyed one fan and radiator...
This is for a 440 stroker street/strip car.
Check this out. You might change your mind about mechanical fans :D
Yes I have seen the power lost of a mechanical fan. BUT... I've also read a lot of about electric fans failing or not cooling enough and being this will see a lot of street time and some traffic I don't wanna be on the side of the road. Now if it was a pure track car I would probably run electric fans.
wonder how much diff. there is in a 6 blade, to a 7 blade, both 17" , anyone know ?
I found a factory 20" diameter deep pitch clutch fan on Ebay supposedly from a 70s 400 with A/C. I combined it with a Hayden clutch and it fit but I also had a shroud with a 22" opening. Made a big difference in cooling my car.
Frok the MP books, the viscous 5 blade fan is the unit that has the best & most factor.
Not the 7 blade fan.
The electric fan issue is a balancing act of needed cfm vs. amps used since the Alt. is going to be used at a heavier load to feed the power requirements.
This heavier load is seen as drag & it will cost HP.
Shround and fan ... if the fan blade was s a half inch in or out with f the shroud, you will be in good shape.
I installed a 6 blade 18.25" Flex a lite fan, skipped the clutch and installed a spacer.
This way you always have cooling, unless really nasty things happen.
This things moves some air, at idle there is a good air flow which also keeps the under hood temps lower.
At higher rpm's the blades flexes and reduces drag, to save some hp to go to the wheels. :)
Noise is not bad at all, I don't notice any excessive noise coming from this fan at all.
I believe this "direct drive" setup is the most reliable of all.
I have one of those flex fans sitting on the shelf. I tried it in a 600h.p. , 406 , sbc I had, wouldn`t keep it cool. I don`t have room for a bigger fan, than 17" w/ my current shroud, or a clutch fan.
extra amps not an issue w/ mine, I have 130 amp one wire on mine.
My engine had a flex fan on it when I bought it, and I've never found a reason to change. I've used these since 1985 and never had a failure. Meanwhile, I've had two clutch fans fail, so I'm not one of these folks who buys into the whole "clutch fans are more reliable" argument.
How hot does it actually get in the Netherlands?
It stays in the 90s F (32C) here in the summer months.
Never had a mechanical clutch can fail on me.
I have had multiple flex fans come apart on me.
Summer time in the Netherlands can go up to 30 deg, rarely above.
This will be just a few days in the week it might be that high, so yeah out here it is easier to maintain a cool engine.
I run a 6 blade mechanical fan the big heavy steel fan. I was thinking about trying the MARADYNE TEXAS TWISTER it is a 12ounce nylon fan. I had some 165 KW diesel generators with plastic fans I ran them hard never had a failure. I know the diesel never saw 6000 rpm So what do you think,:lol:I'm not scared
