65-440
- 11:46 PM
- Dec 2, 2009
- virginia beach, va
Yes, but the stat is not your problem. I really think you need to look at that radiator, I bet that's the culprit.
Yep!My 1970 FSM shows 190 thermostats for all except 318/383 2bbl got 195 ....
Yes sir. Factory service manuals available here free to download:Well, my car is a 1970, so I suppose the 190 degree thermostat is what I'm supposed to have?
Totally agree. What I'm trying to tell him.Yes, but the stat is not your problem. I really think you need to look at that radiator, I bet that's the culprit.
When someone has been through all the hair pulling, wasted money on ineffective parts, all that jazz chasing down a problem, you want to help anyone else who then is going through it after you.Radiator, fan type, fan spacing from radiator, lower hose collapsing. Could be any, or all, past the thermostat. Easily decided by the way the cooling system is set-up.
Why don't you try without a thermostat, for a run, or two, and see what it does. Not going to say it will cool the system down, but might tell you if you have other problems.
In the day, used to run without a thermostat, if a heating problem was in play. Sometimes, the dang thing would run too cold.
Look at the overall picture, to find out what's going on...including the higher RPMs.
Straight from the FSM for '68 models, Cooling section 7-9.
As a matter of fact, I don't recall even being able to get a higher degree thermostat for these back in those days; those came later, like mid 70's?
Correct, sort of. Once the engine gets to the temperature rating of the thermostat, it opens. It doesn't know if you're sitting still or hauling down the freeway, it's temperature sensitive, as explained in the FSM above.
Agree with all that and although Rock is a good source of parts and info sometimes,The OP's car is a 70, which states 190, like I said. That said, IMHO, 180 is high enough for proper coolant and oil operation. 190 puts you too close to the red zone. Interestingly, rock auto shows a 195 as OEM for a 69 HEMI roadrunner
Not correcting as much as clarifying your statement for others. You said:I know how a stat works. My point was clear - please reread before correcting me. Based on the symptoms and the fact that the car stays cool at idle, the stat isn't the problem.
that could be misconstrued, obviously - the stat doesn't open as a result of the engine idling, of course.at idle it opens and keeps the engine regulated.
Thank you all, looks like we have a consensus that not enough radiator is the cause of the problem?
Not so fast, not entirely accurate. I've never ran a spring, never had a lower hose collapse. Zero new cars run springs in hoses, haven't seen those since the late 90's/ early 2000's. Honestly never even heard hard facts as to why they're there in the first place, too much opinions on that. If the lower hose is collapsing you have something wrong causing that to happen. The fact that he's "only" reaching 200 at Hwy speeds, I think his car is working just fine, we're just chasing to shave off a few degrees .....Rad swap is last. Lots of good advice up above. First, give the lower hose a squeeze and feel if there is a spring in it. If not, that's your problem.
There are actually videos on YT right now of 440s on dynos sucking the lower hose collapsed; been there seen that, even on my own car.Not so fast, not entirely accurate. I've never ran a spring, never had a lower hose collapse. Zero new cars run springs in hoses, haven't seen those since the late 90's/ early 2000's. Honestly never even heard hard facts as to why they're there in the first place, too much opinions on that. If the lower hose is collapsing you have something wrong causing that to happen. The fact that he's "only" reaching 200 at Hwy speeds, I think his car is working just fine, we're just chasing to shave off a few degrees .....
I understand that, I've heard this many times. All I'm saying is if your hose is collapsing it's due to another issue. A spring is just a band - aid to cover the real culprit. I proper working coolant system will not allow a hose to collapse ....There are actually videos on YT right now of 440s on dynos sucking the lower hose collapsed; been there seen that, even on my own car.
I made a spring for it just for peace of mind, after having zero luck finding one online (other than from that wonky Mustang parts supplier).
I'm not sure what could cause such (other than an old/soft hose itself, of course).I understand that, I've heard this many times. All I'm saying is if your hose is collapsing it's due to another issue. A spring is just a band - aid to cover the real culprit. I proper working coolant system will not allow a hose to collapse ....
Pretty much what I did, yeah. I figured it didn't hurt a thing having one in there.A stainless tig rod is perfect for making a spring in the lower hose.
All I'm saying is that if the car isn't getting "too hot" at idle, yet IS getting too hot cruising down the highway then that's a radiator issue, short of there being some huge air restriction getting through the radiator.That's fair, I think we can agree though that replacing the radiator is certainly not the first step.
restriction, too much air in the system, or the most over looked item .... radiator cap ! If there was a restriction you'd definitely be running hot at idle though.I'm not sure what could cause such (other than an old/soft hose itself, of course).
Restriction in the radiator?
My bottom hose is a new Gates and it's plenty soft, easily collapsed by hand.
We do know hoses pretty much had springs in them routinely "back when" and they don't now. Must be a reason.
