I did receive the 59 Chrysler core and it looks promising - Looks like a 1/2 longer version of the 383 one. Hope I have the nomenclature straight enough. This is the RB shaft
Both shafts side by side. The LC 36 is the 383 and the LA is the 59 RB. The 59 RB shaft is #1AZ1039LA. The cam stop is LA. The cam plate is marked LC.
The 383 DP shaft cam plate is LB with a LC cam stop on top the shaft.
Tag on housing of 59 dist
Interesting is the 59 shaft seems to be .003" larger diameter (I measured it). It fits tight in the 383 housing - seemingly in the area where the 2nd top bushing was installed in the top of the 383 housing. The 59 shaft looks straight and fits close in the 59 housing and spins good. I will try to set it up in something to spin it and check for any runout on the shaft with a dial indicator.
My hopes were to use the 383 DP cam stop and points plate on the 59 shaft. Do you see any problems so far?
