asaya
my 69 RR is a numbers matching engine/tran etc car. I believe the car was involved in an accident and the driver side fender was replaced. I also think the car was not delivered with air grabber package but now has air grabber probably as a result of the same accident. I found the broadcast sheet under the seat big question is can I get a fender tag reproduced from the data on the broadcast sheet? If so any vendors that you would recommend.
Many thanks for any info you can provide
