Wietse
Hey all,
This came across the forum quite a lot during search but did not really find a thread where they were using my combination, so therefore I created a new one.
My car, '69 Coronet R/T with 440 4-barrel engine came with the N96 option, only the dual hood scoop is left on the hood and the Ramcharger ducting below the hood is missing.
At the moment the engine has a Edelbrock Performer RPM intake with a Holley 4150 4-barrel 750cfm carb on the top.
Most likely this is why someone removed the Ramcharger assembly to get it to fit, but I would like to build that back but I don't want to loose the Holley carb.
I already found that the Performer RPM is too high to use for this (5.30"), so I was wondering someone drives a certain setup with the carburator?
I did see that the older model "Performer" intake is around 1" (4.35") lower but I am not sure if that will give enough clearance.
Maybe there is a intake available with stock size but with improved internals?
Anyone using the 4150 with a Ramcharger hood?
