what gas to use
5:26 PM
miami
i have a 1970 roadrunner with a 440 with an aftermarket camshaft, the fuel gauge is at less then 1/4 and i am wondering what octane i should put in the car.
thanks
Just to be safe go with the 93 octane for now. then maybe try some 89 next time (1/2 tank or so) so that if it pings you can add the rest in 93 octane.
What's your cranking compression? Do you know exactly what cam it has? Most engines with small cams and 8.5:1 CR that blow 150-160 PSI can get by with 87 octane. Starting with high octane and working down until you find the limit isn't a bad idea.
