68sportsatelliteragtop
I am working on the front end of the Satellite and am installing a PST poly kit. The poly kit comes w/ both poly and rubber LCA bushings. From what I read off the Firm Feel site if you use the poly LCA bushings you need a set of adjustable front struts to insure positive caster and a stable toe setting. Guess this explains the tire wear on the Belvedere as I used the poly bushings w/stock strut rods.That being said I am using the stock rubber type this time and just spent about an hour with a punch and chisel removing the old outer shells. Anybody got a better method before I start round 2 on the other side?Heres a couple pics after I blasted and powdercoated the pieces and now have them ready to reinstall.
