help / info and linkage needed
44070dart
9:09 AM
right behind you
just got done installing 440 in my 63 dodge.. need carb linkage info what I need and where to get it ... gas pedal linkage ..thanks
What carb are you using?
If it's a Holley, you need to order up part 20-7 Chrysler throttle extension lever. That will get the correct geometry for the throttle cable to attach.
For the cable, local parts store should have what you need:
Cables with ROUND METAL firewall fitting
19.2” #CA-8417
24.6” #CA-8418
27.3” #CA-8670
28” #CA-8406
Imperial Services also has cables but they are spendy (about triple the price) compared to the above.
For the throttle cable bracket, Mancini Racing carries a neat piece made by AREnginnering that is adjustable.
Or, you can go completely to a Lokar aftermarket setup.
Why not go with Lo Kar setup
I think you'll find Bouchillon's setup has Lo Kar beat hands down,it works without giving you fits and it is less expensive..
