66 coronet steering column will it fit a 67 dodge coronet
moparjohnny
8:38 PM
ga
will there be any difference in steering column for these two cars,steering column came from 66 coronet? thanks
Steering column
Hey Johnny, The Column's should be all the same between 66-67, as long as it's for the correct steering box, manual or power. I hope this make's thing's a little clearer for you.
Major difference is the 67 is supposed to be a collapsible column. I have a 67 that's out of the car if you want to double check the length...
Isn't the 66 narrower (smaller in diameter)?
Correct - the '67 column is collapsible, has a bigger diameter and the bracket that sandwiches it to the dash is entirely different.
