Trans cooler line routing
68sportsatelliteragtop
10:17 AM
Southern MD
I am working on installing a 26" alum radiator into the Satellite and would like to keep the auxillary cooler.My question is it better to send the fluid into the aux. cooler first, or the radiator first? Also which fitting on the trans is the pressure side, front or rear?
i might be misunderstanding something here but if you use an auxillary or tranny cooler why would you use the bottom tank of the rad. it has always been my belief that once you put on the tranny cooler you don't need the bottom tank of the motor cooler. .02 cents
OP is correct,,,, use both.
You should run it into the radiators cooler first, then go into the Aux cooler and finaly back to the trans.
I believe the line closest to the front is the out "high pressure" line.
