67 Satellite 440 with Tremec 5spd.
plymouth67
12:46 AM
Illinios
Kicking around the idea of moving on. I have 67 Satellite originally a 383 4spd. car now has a 440 with a Tremec 5spd. The motor has less than 4000 miles on since I built it last fall. It has Kieth Black 184 quench dome pistons with speed pro chrome moley rings,Clevitte bearings, Speed Pro high volume oil pump, M.P. 509 lift cam,452 cast heads with Edelbrock Performer R.P.M. valve springs,Edelbrock Performer R.P.M. intake with a 750 Holley carb. Pro Billet dist., headers, T.T.I. x-pipe with dynomax mufflers, also has a Be Cool aluminum radiator with dual electric fans. The Tremec is the T.K.O. 500 with a McCloed 10.5 street twin clutch. Car has an 8.75 rear end with new Motive Gear 4.10 sure grip. The car also has all new P.S.T. front susp. with sway bar, M.P. spring relocation kit, the frame has been tied (bolted and welded) it also has S.S.B.C. disc brakes all the way around with stainless steel lines, newer Vintage Wheel Works Tourque Thrust wheels and good tires. I would trade for the right car, 69 to 71 Super Bee, 70 Charger, 70 R.R. or a 70 E body. OR....... make it interesting, dont really know how serious I am just cant stop looking.
Forgot to name a price. lets start at $16,000.00
Please delete this post as I have been threatened with bodily harm from my wife and several friends. Sorry!
Beautiful...if I could get a buyer for My 72 demon I'd be talking to You
demon
pic
How did the trans fit in the car? Did you have to do any mods to the floor?? Im wanting to put one in my 67 coronet but have heard stories of cutting the floor pan to make it fit. Just put a new pan in and really dont want to cut it up..
On this year of Tremec you have to cut a small hole in the center of the tunnel because the shifter come straight out the top. The new ones they have chaged it for Mopars to where you can get a shifter that comes through the factory spot in the floor for factory 4spd. cars. The hole in the floor is really no bigger than a pop can.
I found something that really interests me so if anybody is interested send me a p.m.
70 Superbee. originally 383 4 speed. now 440 4 speed. If interested let me know. We are asking 26K.
x
they fit good, but you will have to cut the floor. at least i had to.
Did I mention that almost all the mechanical stuff has less than 4000 miles on it. This car is turn key shouldn't have to do any wrenching on it unless you want to.
The hottest its been in the heat of summer is 195. The fans are on a switch that kicks them on at 195 and shuts them off at 175.
interesting....looking real good
