70 Air Grabber hood question
RRunner70
11:16 AM
texas
Anyone abel to post a pic and description of the bolt or sheet metal screw that holds up the back part of the air grabber box indicated in the pic attached so I can dig thru my stuff to see if I have it?
Thanks to everyone here !!!!!!!!
air grabber
look in my gallery dude. my road runner is put away for the winter but im sure theres a pic of what you need someplace in there...orrrrrrrrrrrrrrrr....i can look on my computer,,,hold on...........ok,,,found one,,,here
Looks like it might be a sheet metal screw with a bolt head on it. Or it might be an actual bolt with a large washer. Ok Im getting closer ! Just need to see what type of threads it has now and a length. Im betting I have it as I throw nothing away just need to sort thru my pile of bolts and screws!
Thanks for the help !
it is a pointy sheet metal screw/bolt with a 7/16 or 3/8 head and permanent washer . its about one inch in legnth. my road runner is not here or i would verify it 4 ya !
Im pretty sure i found it thanks for the help !!!!!
Any idea who makes a repo air seal for the air box mine is dry rotted.
Hey 70...it's the same screw as you have holding the air seal on...just had mine apart freshening things up a bit....
Herb's in another source for the seal...
