8 3/4 question
efriedrich
3:05 AM
Indiana
Will any of he 8 3/4 rear differentials bolt up to a 77 Cordoba without modification.
I believe the 73-74 B-Body 8.75's will be a direct bolt in to your car.
The 71-72's will work but the rear suspension is a little different but the rear can be made to work.
To verify, measure the rear track of your car. With the tires on, measure across from center to center of the rear tires. Then find an 8.75 that matches your rear track.
I hope this helps,
Joe
The width of the spring pads are different....not a big deal if you can weld.
I hope this helps,
Joe
Also depending on the wheel well width you can gain a pretty good bit of variation (wiggle room) using rims with different set backs. Having to moving spring pads is easy enough and it opens up your choices. Good Luck!!
