ok,,,,heres the dillio. my speedo was reading 10 mph slower than my GPS....I.E...... if the GPS said i was going 50 mph....the speedo said i was going 40 mph...SOOOOOOOOO..... i asked you guys how to fix this and yall said " new speedo pinion gear with 36 teeth, the RED one. well...i just replaced the speedo gear. there was a 39 tooth GREEN one in there and i put in the RED 36 tooth gear. its still; reading the exact same. WHY is the question.
3:55 rear end gears and the back tires are 27 inches in diameter...the chart was calling for a 36 tooth RED gear.
the green gear was a bigger circumference than the red gear so this should speed up my speedo,,,,RIGHT??? what am i missing here????
( yes i know its a 3:55...i checked.....wheel back turns once and the driveshaft turns 3 and 1/2 times = 3:55)
(yes also...the indicator is at 6 o'clock with the proper numbers at the bottom)
IM BAFFLED!
IM BAFFLED!
