crossram for Hemi
69Ranger
11:26 PM
Munich, Germany
I found a nice 528 crate and would like to go for a crossram. Does anyone has an idea where to buy all parts needed, e.g. carbs, linkage, air horns, etc? Any recommendations where to buy, what to consider, no-gos, common mistakes?
Thanks a lot in advance.
mancini racing is a good supplier.carbs depend on your motor specs and what you are doing with it.but mancini has all the manifolds and linkages.
Go right to A&A transmission and cut out the middle man. Rick is a great guy to work with and they have all the items right on there website.
You can also try the crossram connection.
Or go to your local mopar dealer...they have everything you need in the their performance cataloge. The mopar crossram is not an exact duplicate of the original but it is also a grand cheaper than A and A manifold. It is an inch taller however than the origninal if that makes a difference. Spook.
yep, like stated. A&A has all the linkage and alot of other little stuff.
Norm Brady, "HE" is the guy that manufactures these parts. Cross Ram Connections.....NO MIDDLE MAN HERE FOR SURE..............
