piwo440
- 8:09 PM
- Nov 6, 2010
- South Milwaukee, Wisconsin
I have another thread going on here about my 66 Charger build and I appreciate all the comments, but now I want to see if I can get any and all opinions on finishing up the motor build. Specifically I would like to know what you guys would use for this build as far as heads, rockers, converter, intake, carb, rear gears, etc....
Here is what I have. Early 400 block now at 469 ci. Eagle crank and rods, JE pistons. Comp cam and lifters (solid) 540 lift. High volume oil pump with a hemi pick up.
Trans is a 727 with a TCI full manual reverse valve body.
8 3/4 rear with 3:23 sure grip
right now I have a set of 906 heads and a set of 516 heads (untouched)
The car is going to be driven, mostly around town... with a few passes down the 1/4 mile every once in awhile.
I'm looking for any and all opinions, what combos would work best etc... single plane or dual plane intake, 3:23 gears or something like a 4:30, build my 906 heads or go aftermarket aluminum, rocker shaft assemblies, etc...
Thanks very much!!
Thanks very much!!
