REar window clips
al383
7:59 AM
Barto PA.
I'm getting ready to install deck filler panel on my 1969 superbee.When i ordered the new one i thought it would have holes in it for trim clips.does anyone have measurements or pic. so i can put holes in correct spot. Thank You in advance for help.
You will have to dry run all your trim. Spot these holes through the clip and drill into your deck filler panel like I did. If your clip sits to low or high your trim will follow that. Here is a picture of clip
Do you have your original trim for the rear window? If so, look on the backside of the trim. If the clips were a bit rusted, you'll see a trace of that where they sat against the trim. Lay the trim down in place and mark the areas for the holes. The trim clip should be pretty much bottomed out when installed, thus just a tad lower than 1/16" from the top lip of the clip to the top of the panel. The rear window trim clip kits sold today pretty much suck. They're a tad different than factory as is; when they're securely tightened, they sit hard flush against the body. They sit too tight against the panel for the trim to slide between. When I installed mine on my 69' roadrunner, I installed the clips, then taped in a nylon wedge between the trim clip and body, just to make the clip bow out a bit more. I also secured the screws lightly so there's a little give. I backed the screws with some black ribbon tape/seal as an extra guarantee the screws were not gonna budge down the road.
Good luck
Good luck
I agree with everything you said. I started a whole thread on this topic. I had to tweak each clip so they were not so tight against the car and would flex before I installed them. Also had to drill all new holes to get the trim to sit flush with the top of the car because I had new quarter panels.
Dave I hate to hear this, have installed clips and rear window is in. Car in paint booth. I only did the lower ones and notice they were a lot harder then the top ones. How do I fix this before i try and put the trim back on? Can I do something without pulling the rear glass out?
Dave F
Sorry to hear you ran into the same issues Dave. I was at the point of putting a want ad for old trim clips I was getting go frustrated. Finally had to regroup and come up with a decent game plan. Who whould have thought a $20 dollar trim clip set would create such a headache. Goes to show how folks will sell something that should work supposedly to make a dime, then call it a replacement part on top of it..
Here's measurements taken off of a 2 door 69 Coronet. 3/8" depth for the holes from the body side edge.
Yeah thanks PROPWASH. A lot of people are having a hard time with those clips that don't flex. You will learn a lot from people like you and myself who have run into these problems. Even though I got my new clips from rt specialtys. I tweaked them a bit because the trim is right against that paint job and the last thing anybody wants to do is chip there paint in this area. PATIENCE IS A VIRTUE. WHEN I RUN INTO A PROBLEM. I DONT RUSH TO FIX IT BUT WAY OUT MY OPTIONS.I
Nice job
Nice job there "coledavis01". :hello2: Very well done & exactly right!! 9 across the bottom & the clips should look like this. NOS on the left & repro`s on the right.
Hey Guys I just want to say thank you for all the great feed back,with all this info. I belive my problem is sloved.
