69 sport satellite rear end ??
Bens69PlymouthSatellite
10:10 PM
IN.
Does anybody know if they ever put an 8.25 rear end in a 69 sport satellite with a 318 engine in it,every thing I found says it should be an 8.75 but the guy who sold it to me said it was an 8.25 how do i tell if its an 8.75?thanks aton
If it is a 8 1/4 it has a removable rear cover!Never seen or heard of one in a bbody,someone put it there.moparsteve
I had a 8.25 in my Coronet 1970 original 318 904 I guess all B-body 69-70 with straight 6 and 318 904 had it, the 8 3/4 was to expensive to fabricate thats why they replaced it.
Actually the 8.25 was quite common. Ive got a couple laying around out of 68-70 b's. Not the strongest will hold up to most small blocks (mild not 600 horse.)
I have a 8-1/4 here are pics for comparison.
Thanks alot,I have an 8.75 rear end that Im going to swap out if it doesnt already have one,are there any modifications I have to make to swap them out?
Driveshaft should be 0.66" shorter I guess thats the only thing thats not the same.
Also need to confirm its from a similar b body. It changes between a, b, e, etc bodies as far as width and mounts for your suspension. Even some b's are different. I have a rear from a 71-74 station wagon b body thats almost 5 inches wider. Just double check all your measurements.
Thanks to all of you,just as one more question what can i use to clean the rust off the 8.75 rear end that I have I would say its as rusty as the pic above,thanks alot as always!
would a decent palm sander work? and if so what grain paper should i use,any input would help,thanks.
I think I would use a good wire wheel on a 4" grinder before a palm sander.
That was actually gonna be my next question! should I use a brass wire wheel? or does it matter?
Well hopefully that means I do have an 8.75, if I do have 2 after all, maybe I will put one up for sale on here,thanks alot for all your help as usual u all are awesome
I had a 69 318 Charger (wish I had it back) and it had a 2.71 8.25".
Just get yourself an el cheapo harbor freight blaster and go to town.
