3-speed wipermotor
Haflinger
5:42 PM
Belgium
I bought a new concours wipermotor for my -68 Charger but evidently it's a late car so it should have the one for 69-71. I guess the armsystem
differs since the outgoing axle of the motor is excentric on the -68 and
not on the -69-71. Any ideas?
It is quite an expensive undertaking to convert from 2 speed to 3 speed wipers to buy all of the required items.
The wiper motor itself will not give you three speeds or work properly by itself. You need a three speed dash switch and the correct linkage. I belive that the linkage cam is available repro. I would check with Julies the Wiperman regarding this issue and availablility.
Thanks for your input but the motor I have is a 3-speed but the difference
between early -68 and the rest is the outgoing shaft. The later just turns
around while theearly one I have has an excentric move. My thought was
to only swap that axle.
Again, jules the Wiper man knows nore about these things than anyone and should be able to help you out.
