Belvedere rear ends
oliver
4:04 PM
SF bay area
Put my new 66 belvy with a slant and 3 speed manual on the lift and noticed that i came with a 7.25" rear axle:gah: I thought the smallest rear end available on them were the 8.25"... i also noticed that in this chart
the 7.25 was never available.... i was going to just regear when i swap in my small block but now it seems like i have to do a rear end swap. If i end up finding a 8 3/4 i did notice the width between the spring perches are different, how did they mount the springs closer together? Should i keep the stock width and reweld, or change the mounting on the car? Thanks!
I don't know if that chart is completely accurate. I could be mistaken, but I had a 68 Belvedere slant 6 3 spd with a 7.25 rear end.
One way to change the spring width is to use offset shackles and modified front hanger. Also the chart says the 8.25" B body and the 8.75" 62-70 B body has a different spring CL width. I don't recall having that issue.
My 69 came with a 8.25 and I swapped a 8.75 with no problems. Width matched perfect.
Randy
I too saw a lot of 7.25's in B Bodies and they do NOT take any kind of abuse.
As for the 8-3/4 difference I think when you get the 8-3/4 you also got a heavier duty leaf spring (wider also) which if swapped as an assy springs and axle it would bolt right in with the difference being leaf spring width which when split between the 2 would be 1/2" per side centerline pivot. I do not think the factory tooled up different uni bodies for 7.25 rear axles, only the hanger brackets, springs and shackles and shock plates and axle.
If your gonna swap out the rear axle go with the 8-3/4 for sure, there should still be plenty of housings floating around.
What do you think would be required to swap in a 8 3/4 into the car? The front mount and shackle mounts are in different locations than 8 3/4 cars. How do they differ?
Yeah, that chart isn't complete.
Take a few measurements, the important one being the spring perch width. For your car, it should be 44". If there's nothing odd going on with your car, then it should be just a matter of pulling the 7.25 and installing the appropriate 8.75 rear. I'd say stick with a 64-67 B-body rear (earlier than that had the 2 piece axles IIRC), but you would likely be OK with a 68-70 B-body rear - my notes say the 68-70s were slightly wider (like 5/8" overall WMS to WMS). Both of those have the spring perches set at 44" apart.
Be sure to get an accurate measure on any rear you buy! I picked up an E-body 8.75 for my 68 B-body (the E-body rear is 1.5" wider than a '68 B-body rear) which supposedly had the perches relocated for a B-body. My quick measurement wasn't good enough - turns out the perches were set 1/2" narrower than a A-body rear. So, off they came and I welded on new perches at the right width which also allowed me to set the pinion angle just right for my car. Worked out in the end... but meant more work than I had anticipated.
I don't think, I know it's not. 65-67 8 3/4's are't the same as 68-70, they aren't as wide. That chart shows 68-70 spec's. I also thought the 8 1/4 came along in 69.
Do you know how much is that difference?
Here's a chart I pulled from somewhere on the 'net:
All measurements are from brake drum to brake drum:
1966-'72 A-bodies 57-1/8 in.
1962-'63 B-bodies 58½ in.
1964-'67 B-bodies 59½ in.
1970-'71 Imperial 59¾ in.
1968-'70 B-bodies 60-1/8 in.
1970-'74 E-bodies 61-5/8 in.
1965-'69 C-bodies 61¾ in.
1965-'70 A100 vans 61¾ in.
1965-'66 Imperial 62 in.
1967-'69 Imperial 62-5/16 in.
1970-'71 C-bodies 63 in.
1971-'74 B-Bodies 63 in.
1965-'71 D100 trucks 64 in.
1969 C-body wagons 64-3/8 in.
1971-'73 B-Body wagons 64-3/8 in.
1970-'73 C-bodies 64-3/8 in.
1972-'74 D100 pickups 64-3/8 in.
When I put an 8 3/4 into my 66 Belvedere, all I had to do was change out the u-bolts and shock plates. IIRC, the dinky rear has smaller diameter tubes. It's been 18 years ago that I did that so some one correct me if I'm wrong. And was it a 7 1/4 or 7 3/8 those things had? Mine was a /6 auto and it even came with 10x 1.5 rear drums. Find shoes for that let alone the drums....
It worked for me...
Went there and clicked on the file and seems it's corrupt....
Did you get all 100+MB of the zip?
It worked for me I just now downloaded it and was able to open and extract files from the zip with no issues.
I'll try it with a different machine....don't want to go through that again with this one lol
