How to restore an A833
68GTX4SPEED
11:29 AM
Sweden
Anyone here who know where I can buy a book just like the
Torqueflite A727 transmission handbook but for the A833 manuel transmission.
Thanks, that will be one of my job this winter to restore 2 transmisssions.
to my knowledge a book like that doesnt exist
I will suggest you pick up a used counter shaft cut it down so it's the same size as the cluster gear(Your making a dummy shaft ) when u put the bearings in the gear slide the dummy shaft in to hold bearings when you position it in the case and slide the actual shaft in it will push out the dummy shaft and you wont lose the bearings
a real time saver
Thanks for that one, the book was for sale and I order one from Mopartsdealer but they were already soldout when my order came to him.
I have several manuals will look into these tonight:sleepy2:
I will suggest you pick up a used counter shaft cut it down so it's the same size as the cluster gear(Your making a dummy shaft ) when u put the bearings in the gear slide the dummy shaft in to hold bearings when you position it in the case and slide the actual shaft in it will push out the dummy shaft and you wont lose the bearings a real time saver
I use a wooden dowel instead of a metal one. You can buy the dowel at most home improvement stores. I use wheel bearing grease to hold all the needle bearings in place as I assemble them. That helps to keep them in place.
working as a rebuilder I had plenty of spare parts laying around
Are they all long gone now? I guess I will need some parts, have some gears with damage, dont know yet if I can reuse them, will post pics later.
Sven
Sven
retired now when I need parts I either use
rockland stand gear
brewers or passion performance
