Shifter
coronet1965
1:29 AM
Milwaukee WI
Does hurst, or another company make a short throw shifter for a 65 coronet with a 4 speed?
Hmm, looking at my 4 speed sitting in my garage just wondering how to make it into a short throw? and why would you want that?
I would have to imagine that all the shifter body and rods would have to be in a kit. along with reverse switch etc.
If anyone would know for sure and have it Brewers would call them.
http://www.brewersperformance.com/category13.asp
Reason being is that the shifter smacks against the dash bad.
I had the same issue with mine. Stops were adjusted properly. I heated and bent the lever back. The area that I heated was dow low and was hidden by the console so nobody is any the wiser.
I Remember That Factory Shifter In My '68 Charger...You Know The One That Makes 86 Bends In It And Seemed To Be As High As The Radio Was. I Still Have Scars Across My Right Knuckles From Punching Out The Radio!
I agree about mopar long throws...My vette and 60's camaro had a short throw and it was so nice banging gears...I have a A body with a small B body pistol grip and it's ok but still not as short a shift
I have a H' comp +, attached to my "stock" Hurst shifter...it's ok.
kind of like Rowing a boat.
it happens to be in "reverse position" on picture
..no banging the dash.
Passon peformance
Heres mine, Jamie at passon performance did mine, No problems.. Mine is in reverse, You can call jamie also he can help you out.
