new to fbbo
jade2ghost
11:07 PM
colorado springs
Hi my name is dario and im new 2 the forum, i have a 1969 gtx clone with a440 wedge with a .30 bore, 727 3 speed with a stall conveter, been working on it for almost a good 8 years and finally after a new engine and transmission finally got it running some what decent, would love if any one could help me with any of the small problems im having or any tips would b greatly appriciated
wiring problems
my main problem is wiring so my question is do u no where 2 get an affodrable new or may a used wiring kit
My 68 Golden Rotiserrie Chicken had all the original wiring harnesses in , and are all beutifull. Check my resto thread. Year One has what you want , but they are pricey. Other members here should chime in with some great other ideas. Good luck
electrical problems are USUALLY something simple and stupid....like bad grounds. if you give explicit detail on what its doing,,,or NOT doing...maybe we can fix the probs here ....waddayathink?
Welcome to FBBO, good luck with the electronics/wiring issues...
Bulkhead connection on the firewall
Dario; Check the bulkhead connections on the firewall, main wiring harness/bulkhead connections, many of the electrical problems are attributed these connections, also to bad corroded rusty burnt/fried connections in those 3 connectors in the main bulkhead {or any other places on these 40 year old cars}, take it apart very carefully, they can be really brittle plastic & can break very easily, clean the connections, both sides, with small brass or stainless wire brushes, pipe cleaners, toothpicks, toothbrushes what ever works, etc., then use an aerosol electrical spray cleaner, that will evaporate & not leave any residue, to get the rest of the bulk of the corrosion rusty oxidation type crud out, when reassembling them or any other electrical connections, use some dielectric grease on each individual connection, it will help with connectivity or continuity & keep out moisture, that is the main cause of the problem in the 1st place... Also grounds need to good everywhere, I have added grounds to insure better continuity, you should use a sufficient size Ga. wire & solder the ends & use shrink tube to seal them {#6 is what I used}, I have grounds from the engine to the firewall, from the alternator housing to the body, from the body to the sub-frame & use star washers under all the connections at ground... There is a great website www.madelectrical.com , great tech tips, schematics/wire diagrams, relays, fuse-able links, in-line fuses & connectors, arming switches, breakers, wiring, connectors & supply's etc., there are many other tricks, all the under-dash, engine & lighting harness go thru a large black wire that goes to & thru the AMP gauge, you can relieve some of the path traveled by adding a #8Ga. wire from the main 12volt charging terminal/threaded 1/4" stud on the back of the alternator to the Starter Relay under the main bulkhead connector, 5/16" main large threaded terminal {it shortens the path the charging system wiring & take some of the load off the AMP gauge connections}... Post a separate thread on your problems, in the appropriate section, someone here can usually help you & it will get allot more exposure than just the Welcome Wagon section... The photos belw are just examples of where problems can be found like, gauge clusters printed circut boards {Charger example} Starter relays, voltage limiters, different types of voltage regulators & alternators, ignition & wiring...
  • Mopar Elec. Ign. wire diagram 4 pin Ballast & electronic regulator #11.jpg
budnicks, i really appreciate all the help and tips, i dnt no how u knew bt all the pictures n diagrams seem 2 be everything im having problems with lol, i will definenlty take a closer look at them n trace all my wiring n grounds, and thank all of u for welcoming here 2 the forum
Tpodwdog, my car wasnt starting at first, bt like u said it was a bad ground 2 my starter relay, it starts now bt i have a lil problem with keeping my battery charged, it will stayed charged 4 like 3 weeks or so, ive traced my wiring n it all seem hooked up rite bt i have so may spliced wires from previous owners that now im just trying to sort them all out 2 find out which ones my car needs and doesnt, im honestly trying to find a new or used wiring kit just 2 redo it all cuz not all my wires match color wise 2 the wiring schematics
Common stuff
Your welcome "sorry, 1.5 months, kind of late", pretty common issues, I covered there...
