bandit
Unreal, I changed out my both head gaskets and get to the end of putting everything back together and I break a valve cover bolt off in the head. Arghhh!!!!! Was tightening it to service manual specs and it just went loose. It is flush to the head so no where to grip it. I would just try and drill it out but am freaked out about getting metal shaving down in there. On top of it I also find the corner bolt hole for the valve cover on the same side is cracked in half (actually fell off) and will not hold a bolt. (this corner bolt hole is in a nub piece that sticks out of the head so nothing major cracked on the head, just this mounting hole) I had the heads machined so have no idea if this is something he did or me. So now I have one side with two bolts missing. They are not next to each other thankfully and the cover seems pretty snug without them.
I do not want to do this whole job over again and take the head back off and I'm not even sure if this corner broken off piece could be fixed. What is the opinion on going without two bolts on the valve cover? Or is this one where I have no choice and have to redo this whole job so I can get the head out and have to buy all new gaskets again for everything? I haven't put the rest back together yet to fire it up and see if this will leak or not. This kind of stopped me in my tracks.
