What size are big block pulleys?
74sundance
1:03 PM
ontario,Canada
Hey guy's I went to Moparfest to day in search of a bunch of parts for my 1976 big block 400ci motor in a 1974 Plymouth Satellite. and found most of the stuff I needed but I'm, having a problem with 2 pulleys I got.The crank and water pump pulleys are hitting each other,I'm sure the A/C 4 grove crank pulley is ok but the Water pump pulley's diameter must be to big.Doe's any one know the size/s of pulleys I would need? I'm able to go back to Moparfest tomorrow if I get some answers today.Thank's in advance :)
most water pump pulleys i know of are 6 13/16 inchs diameter.
Hmmmmmmm?
As you can see the water pump pulley is way down in between the groove of the crankshaft pulley
thats because you have the wrong crank pulley. you cant use a non AC top pulley with an AC crank pulley. the crank pulley you need has 2 grooves with the inside pulley having a smaller diameter. disregard the a/c compressor on the 440 below, thats not factory
I love the pic of the low mounted A/C compressor.
Did it work? What compressor did you use?
If this works and the parts are available I want it.
Thanks in advance
:icon_fU:
Thanks in advance
:icon_fU:
Follow the link in Cranky's post, they sell the set up.
I ended up,putting the body panels on the car and selling it as is.I would have loved to finish this car but I had to bring my Sundance home and just didn't have the room.
