Swap from 8 3/4 to dana drive shaft length
apace777
New Member
6:56 AM
new york
Swapping my 70 roadrunner 8 3/4 to a 70 dana does any one no if drive shaft length is same ,the rear is being rebuilt and havent taken any measurments
You'll need a shaft that about 1" shorter...but do a mock up first before cutting or take actual measurements once the Dana is in.
I did that swap in my '70 roadrunner too. I had the driveshaft cut 1 1/10 inches shorter. I could have used 1 1/8 but stuck to what the tape said. It fit fine.
-=Photon440=-
im doing this exact swap today i will take some pictures and post them
you will need a dana drive shaft
What's the difference between a Dana shaft and any other heavy duty shaft that came in the Mopar high performance lineup?
You don't need a Dana drive shaft, I didn't use one. However, the universal joints are different sizes. You need a combination u-joint to put the 8 3/4 driveshaft onto the Dana 60. (I don't remember the dimensions right now or I'd post just the singe u-joint)
http://theujointstore.com/cou.html
-=Photon440=-
Dana uses the same shaft and joints as the 8.75 in an HP car but is about 1-1/8" shorter. Non-HP 8.75 will have the smaller joints.
Soooooooo 777 you should just have to shorten your RR shaft.
:blob1::blob1::blob1:
