Steering wheel cap removal
nakabrd
4:37 AM
Bakersfield, CA.
I have a '71 Road Runner with the deluxe steering wheel that has the 3 winged center cover with road runner picture in the middle. What is the trick to removing that center cover? Thanks for your help.
If you look close at the button, You'll see there is a small notch in the button. Use a vinyl trim tool or something light and use that notch to work out the button. There is a small bolt under that to remove, then the center 3 winged cover comes off. Be careful the print/sticker material on the back side of the roadrunner button comes off/scratches real easy.
