Ground Strap
1966 Hemi
3:20 AM
Orlando
Would someone please tell me where the engine ground strap is located on a 1966 Hemi Satellite?? I believe that it goes from the Block to the fire wall?? -Rich
is it at the back driver side? if not there driver side front. if it is even there at all
they all go from the block to the fire wall hemi or not. put one on the battery negative to the rad support also...if its not there already.
strap goes from block to firewall, there should be a hole right around the heater hose nipples for the core
Bryan
