Bruzilla
- 10:27 PM
- Jan 11, 2012
- Orange Park, FL
Way back about 1985, I stopped at the Pizza Hut on Pacific Ave in Virginia Beach. There were three Hemi Superbirds there, and the owners were going to some NHOA event.
One of the Superbirds had a pistol-grip shifter and another lever next to it. When I asked what that lever was, the owner moved it and the Angle of Attack (AOA) of the center section of the wing changed. I didn't ask if it was an electrical or mechanical mechanism, but it sure looked cool, especially to an aviation guy with a fixation on moveable control surfaces.
I was thinking I might try a similar set up on the go wing I just installed. I'm thinking of drilling a small hole in the trunk lid, and mounting a 12VDC microwave oven turntable motor to the underside of the trunk lid with the drive shaft extending through the hole. These are small, flat, very high torque/low RPM motors and made to spin Aunt Minnie's Death By Cheese casserole on Sunday nights so they should be able to handle this job. I would then mount a threaded swag bar from a hanging lamp (hollow on the inside/threaded on the outside) to the motor drive shaft.
On the wing, about three-quarters from the front, I would drill a hole and epoxy a washer and a nut that matched up to the swag bar. The swag bar would thread through the nut and into the wing. Turn it one way, the wing tilts forward, turn the motor the other way and the wing tilts backwards, all controlled by a double pole rocker switch on the console.
I don't know if it'll have any impact on performance, but it sure would look cool making the wing tilt change while you're setting up for the green. Maybe some intimidation factor there. ;)
