low hum near water pump.in my 225 slant 6.
Bear R.-
12:51 AM
snowflake arizona
hi Bear R.- here.i have a low hum in idle what seems to be coming from the water pump/harmonic balancer area.any idea what this is?need to pin point this.its friggin driving me nuts.and getting tired of this one thing after another thing.i guess thats what happens when you get a ride that been sitting for 10 plus yrs..thanks and God Bless, Barry.
Is it like hmmmmmmmm or HMMMMMMMMMMM? lol Wish I could help. Could the timing Chain be rubbing the cover?
Do you have power steerin? P/S pumps are notorious for makin noises.
no ower steering.the hum goes away w bit of throttle.also goes away on its own most of the time.if i up the idle a bit it s gone.its when i set the idle down to where its suppose to be.youll hear "occationally"..thanks Bear R.-God Bless .
Is this an automatic car? A lot of times, the torque converter can get a little wear in it and hum like hell....it can radiate all the way through the carnk and can sound like it's RIGHT behind the radiator. Chevy powerglides were real bad about it.
If you run it with the belts disconnected does it go away?
Ron
Ron
Could be the start of a bad alternator bearing. I have used a long screwdriver with the handle against my ear to listen for problems in the past, used for over 30 years in the mills to check for bad bearings.
A screwdrived does work good......but I'll tell you something even better. A long 3/8 drive extension. It has no handle to insulate the sound. That's super important for me because I am very hard of hearing.
thanks Guys i wil be on it just havent got to it yet.and for the question on the auto trans.no its a 3 speed on the colum.let you know very very soon.God Bless you all .Bear R.-thanks for all the help.
"That's super important for me because I am very hard of hearing."
What'd you say, Rusty?
