SOLD somebody around with Carter 10-203 strip klit ?
well I guess that LOL.
primary Jets can be found individually up to .105 but not secondaries :(. Id like to lower a liitle bit the floaters but bigger secondary jets.
Another option could be modify some extras I have around though
It's extremely unlikely you would ever run into a situation where you would need to rejet the secondary side. Ever. 99% of secondary adjustment is done with the air door.
What exactly are you wanting to do? I have several excellent Superquad cores. They were made in the 1980s and were the last of the HP Thermoquads. High flow jets good metering rods even came with electric chokes. I'll sell you a good buildable core.
I want to play with it being my 400 block is stroked now ( 440 crank ). Beside that I'm getting some pinging at certain point of throttle opening with load ( beating hills ), so jetting maybe will help.
I'm raising the floaters from 1" the 6322 TQ should be to 29/32" ( per demonsizzler advice gave me once ), and giving a quarter turn more to the air vent spring. Also got the opening tab adjustment a to open little bit less.
my actual jetting and rods setup is:
.98
2005
.143
Those are the biggers pieces I have got from the 5 or 6 TQ donors I have around
