Propwash
- 12:57 AM
- Oct 29, 2009
- Island of Misfit Toys
Hey guys....
Need some advice with my 512 build. Built plenty of engines with the stock-mild upgrades in the garage, but this 512 i'm stepping up to a new level and I need some help.
Here's the deal. I have a 1974 440 block that just got boiled, checked out good with the Magnaflux and the bore is still pretty much original with no ridge up top.
As far as the somewhat knowns:
Edelbrock RPM Performer heads....84 CC...Looking for a 10:1 (+/- .5) Com ratio. Mild porting to be done
Edelbrock dual quad manifold and carbs (2-600CFM)
1.5 adjustable rockers, pushrods cut/ordered to fit
440 Source Stroker kit (need to figure out a larger bore or longer stroke and dish/flat)
TCI Super Street fighter auto w/3000 stall converter
3.91's in the rear
Distributer (mechanical/Vacuum advance?)
2.5" TTI Headers into 3" to the back
Car is a power brake car
Looking to install a hydraulic flat tappet (low Maint.)
Street/strip with a big majority to street, looking for low to mid torque
So......Don't beat me up too bad on the in depth specifics or to the fact I'm a bit naive to such builds (not too proud to admit it). Also, some parts were bought/some traded/some favors but were compiled mostly to my budget. In this set up I could use some advice on:
1) the cam...it's an automatic and it's a car I would like to use the power brakes without the addition of a vacuum pump. I've been looking at the Comp Xtreme high lift, but the descriptions are pretty vague. Would going with a .564 lift create too loppy of an idle or issues with vacuum? Would a .507 be a better fit and a bit more forgiving or still a bit up there?
2) the bore and stroke....Being the bore is pretty much still at stock with DIA., the door is wide open. With this set up is a longer stroke better or a bigger bore? Also the pistons. thinking I'll use the style for dialing in my comp ratio, but are the other factors to look at as well?
I appreciate any help...Again, most of the builds i've done consisted off the $800 kits you see at summit or from scat/eagle. Tossed is some cams, added-swapped carbs and other mild additions, but this is the furthest outside the box and am looking for some advice from you more experienced gent's on the site, being that the build/internals will be decided by myself and what you have to say, not a builder. So, forgive my ignorance and I really do appreciate the help. I'm excited to learn as well as excited to put fire back in the lungs of my bird.
Thanks,
Will
3.91's in the rear
Thanks,
Will
