Blackcoronet440
Hello, I just recently Blew my 440 to pieces at the track. here is (was) the setup I had going
'66 Coronet440 Full interior car no cage
440 ci .60 over
Forged Aluminum speed pro pistons 10.5: 1 with the RPM's
Stock Rods
Steel Crank
RPM Heads Fully ported/Victor intake
.590 Purple shaft
2" Hooker headers
MP distributor with Chrome Box
727 3500 10" stall 4.56 Gears
Car turned 11.60's @115mph
Now I am looking to build a Motor that's is just as fast if not faster. BUT stronger and lighter internals. Same top end new custom grind solid cam shaft. I have been leaning on the 400 Stroker motor Mainly Because I hear they all screamers! Plus with the added cubes of the stroker I wont have to worry about low end grunt. This motor will be used on the street lightly. (Burger joints, Cruise inns, Car shows and a stop light to stop light Pony Car bruiser) I still need it reliable (Last for a number of years). My last motor ran hard up until it went for 9 years. I know that the 400 will cost a bit more to build as far as buying a new intake that will fit and Distributor. That is the least of my worries. The one thing that bugs me is how short the pistons are in the 400/512 stroker kit. I worry about Piston rock in the cylinders hens lowering the drivabilty and reliability on the street.
I would like some feedback as to if this make sense to do or would going back to a 440/512 kit be better??
Also for info on the stroker kits I have been researching here is a link
http://www.440source.com/strokerkits.htm
Thanks for the input
440 ci .60 over
Stock Rods
Steel Crank
.590 Purple shaft
2" Hooker headers
