383-440-ENGINES ,intakes,heads,+parts ,big list
joel
2:15 AM
edinboro pa
Feedback: 20 / 0 / 0
ENGINES
1965--383 cast 6-7-65 block & steel crank 250.oo
1965 383 clean turns over dated 6-16-65 500.oo
1968--383 cast 12-28-67 assy 1-18-2 non h.p. block &steel crank
1969---383-cast3-3-69 assy 3-21-2 block&steel crank 250.oo
1969--383 cast 4-23-69 block& steel crank 250.oo
1970 383 dated 1-6-70 non h.p. shortblock 350.oo
1970 383 long block dated 10-10 69 H.P. -blockrods&steel crank 450.oo
1971--383 cast 4-19-71 non h.p.block only 250.oo
1971 --383 cast 11-18-71 non h.p. block & steel crank 250.oo
late model 440.short block, steel crank ,
from truck----siezed from sitting 250.oo
late model 440 ,short block, cast crank
siezed from sitting 150.oo
65 413 block dated 4-2-64 no caps 100.oo
62-67 383 iron intake #2205968 100.oo
67-69 440 intake # 2806178 i have the following dates
5-18-68
10-11-67
100.oo
66 440 intake # 2206000 100.oo
65 413 intake # 2206000 100.oo
68-9 383 h.p. intake #2806301
70 440 iron intake #2951736--dated8-23-69 125.oo
71 383 iron intake #2951666 100.oo
72 factory dual plane iron intake#3614014 25.oo
medium rise single plane alum intake 413-440-100.oo
VALVE COVERS
69 440-383 h.p. nice 125.oo pr
71 set 50.oo pr
72 set 100.oo-blaseted primed
no 70s
big block water pump housings original iron diff cast #s avail.
67-70 383-hemi water pump housing #2780987--50.oo
big block power steering brackets 50.oo
big block pow st pump with brackets ,.blasted painted, 100.oo
big block 4 groove crank pulley for steel crank 40.oo
big block steel crank 2 groove crank pulley 40.oo
big block water pump pulley for steel crank motor
40.oo
air cond pulley and bracket for big block steel crank motor 40.oo
non h.p exh. manifolds 40.oo pr many to chosse from
stock rocker shafts 10.oo ea
stock rockers 10.oo-set
stock rocker spacers 10.oo-set
stock bolts and special spacers 10.oo set
located in n.w. penn
u have 440 manifolds? i have a 74 440 im putting in my 70 belvy and need a stock set...any of yours work? need a 4bbl breather and valve covers as well...also all the throttle linkage for a 440..and trans linkage for a 727
i have some non h.p. exhaust manifolds 25.oo ea
i have some stock valve covers of numerous yrs , no 70 s
i have auto throttle bracket 10.oo but no linkage or throttle cable
pm me if your interested
i really need a set of 440 exhaust manifolds...my cars originally a small block v8 car and im putting bigblock v8 in it...iv herd the trans linkage and some of the other linkage wont be long enough for the BB..didnt u have motor mounts as well? wanted them a while back but my budget got tite for a while...if u have maby a package deal for a bunch of stuff like mounts manifolds and some other stuff
i have some non spool type motor mounts 25.oo-40.oo pr
