SOLD (2)15" Steel Wheels
kb67mopar
7:55 AM
Luxemburg, Wi
Feedback: 6 / 0 / 0
I do not know what these are off of, they may not even be mopar wheels as they were on my trailer. They do have tabs for some sort of dog dish cap so if you recognize them let me know what they are.
They are for sale and look to be in pretty good shape.
really, 106 views and nobody can tell me anything about these...come on guys you know more then that.
Well they do look like 68 and up dodge steelies which accept the 9" dogdish caps. When I get home I'll compare your pic to the ones I have as I have a set with 4 tabs and have two with 3 tabs that hold the dish. Also check for a number stamped into the rim close to the lugs. I think mine have a k24 or k25 but will confirm when I get home tonight.
Take a tape measure and measure from the center of one hole to where the center of another WOULD be directly across from the one you started at. That will give you the closest measurement of the bolt pattern.
Thank you, this was what I was looking for. I can't really advertise them well without knowing what they are.
Rusty,
Thanks I know they are 5 on 4.5" My trailer has shared wheels off my Coronet so that has been confirmed (actually the trailer is wearing all wheels that came off my 67 parts car)
ok I got home late and cant get the numbers off the rim but here are pics of the two styles of steelies I have... will try and remember to get the numbers tomorrow after work as well as the width measurement and backspacing measurements for you.
This one is the wider of the two 15" and has 4 points to hold the cap.
This one is the narrower of the two and has 3 points to hold the cap
I can't find any numbers on these wheels. Would they all be inside the wheel under the tire? Anywhere on the outside and I can see nuthin.
Measure the center hole. Ford is smaller than Dodge/Plymouth and won't fit a Mopar because of that.
looks like a 15 x 5 1/2 steel wheel. it very well could be 6 1/2 wide. the size is stamped on the inside where the tire is , you will have to pop the tire off the bead if you want to know what is stamped on it.
Thanks guys. it will be a bit before i get a chance to get the tire loose and measure the center hole, family in town.... But again, thank you for the info.
Check and see if there is a pentastar by the valve stem also could have a part number by the stem if it's a MOPAR wheel.
Ok I have done all the measurments I can think of on these ones I have here. if you want to compare the info tou yours...
The white rim is:
15" x 5 1/2"width
Large bolt pattern 5 x 4 1/2"
2 13/16" center register
3 3/4" backspacing
There is a "12" and a "B" stamped on the lug pad
There is what looks to be white painted on " WA S" and "112589" on the outside between the beads
The Black rim:
15" x 7"width
4 3/8" backspacing
There is a "K25", "MT", "26" and an unknown symbol stamped on the lugpad
There is also the following stamped on the outside between the beads... "CA NA DA 15 x 7 JJ 2 23 85 D K25" and the pentastar symbol.
Hope these help!
Well I took a second look and still I cannot find any stampings. The center register appears to be about the same diameter as your measurements. I guess I will have to pull the tires off and officially make a judgment that way as to what they are.
I never did pull the tire off so I guess I'll make these cheap.
$35+shipping per wheel.
I recently pulled the tires off of these to realize these are not mopar wheels, are not the same width and do not fit the mopar center register. So if you want them let me know otherwise next time I head to the scrap yard they are going.
