newer guy
bmdgraphics
5:43 PM
spokane
Just wanted to say hey while i fiddle with my profile! Glad to be here and owning a wagon on top of it!!!
Anyone know how to rotate pics???
Cool wagon & welcome to FBBO
You have a wagon on top of your profile ? No wonder it needs fiddling. :fucyc:
Welcome aboard.
well i see you figured out how to rotate and then save your picture. Welcome.
what is that thing on the back corner? A mirror?
hey thanks! My file has this as the correct orientation but when i upload it turns.
Yes it is a grab handle with attached wind deflector meant to keep the back window dust free while driving;) It was a stock option from the factory. My car did not come with them, I got them from a junkyard car but they are getting hard to find. I saw a pair on eBay awhile ago for almost $300! My car was very bare bones with no power anything, it did come with a 361 instead of the 318 though. I believe it was ordered to tow because the rear of the car once had a tow set up, the frame at the back bend was reinforced with a plate of steel on both sides, it has helper springs and an old vintage 1960's trailer brake mounted under the steering column. This was obviously someones camping/vacation rig.
Welcome aboard! Nice wagon...
thanks for the splanation' and cool car
Right click it and on the drop down menu it says "open with", then pick paint or it might say "edit", if it does, then click that. When it opens in paint, theres a menu on top , pick rotate, when it shows a box, pick 90 degrees. It'll change. I use paint a lot. And also, when viewing it on your normal photo screen, this might be easier for you, there are 2 mountain looking things at the bottom of the pic. One rotares it right 90 and one rotates it left 90. Click that. It might ask if you wanted to change it. say yes. and rotate through all your photos and all that are in that session that you do that to will stay that way. In that file, if you have copies of those pix somewhere else in other files, they might not be affected.
