WANTED: Column shift linkage for a TF727 '69 RR
eagleone1983
3:04 PM
utah
Apparently my shift linkage is not the right one. I don't have any where to adjust the linkage and per the FSM there should be a screw that the lower link can slide in and out of so you can adjust it.
I have the lower rod with the adjustor. PM sent.
Thanks Don, I may be able to rig my setup so it'll work with that one adjustor rod. I know the square part with the screw some how connects to the crossover linkage so I'm not sure what I'll have to do. I'll try to get a picture to you today. In the mean time if anybody has that full linkage I'm still on the hunt. I'm pretty sure my brackets that hold the crossover link to the transmission and frame rail are correct so I may not need those.
The trans bracket is different from 727 to 904, although the frame bracket is the same for either.
Nothing? Dang. Does anybody know what years are interchangable so I know what to look for?
66-70 B-Body with a 727 column auto will work although early frame and trans brackets used a different bushing arrangement. 70 with a console auto with lock-out system cross shaft is slightly different but it can also be used for column auto 727. I did not get those pics yet?
No I didn't have a chance yet. Thanks for the info though.
I sent the pics to your email Don. Thanks again. Hopefully I can find this linkage at the MATS this weekend
I have 904 linkage but not 727...if you find its the same send me a PM...$25 shipped and its yours
