10 cent Home Depot plug...thanks
Chryco69
7:33 PM
Indiana
Tried to pull out a plug to fit in my sending temp unit
Localized heat and cast iron is always a bad combination. Looks like someone is ordering the aftermarket aluminum water pump housing and pump kit!
I am confused?? Why were you removing a heater hose nipple if you were working on the temp sending unit that is in front between the two bolts?
it was a sensor for the electric fan so that it turns on. Previous owner had cheap plugs in the housing. I am going to get an aluminum one from 440source
I have a stock H2O pump for your BB if you are interested. Might be able to save a few bucks for ya. PM me if interested....cr8crshr/Tuck
water pump
Is it a pass side drop? how much total i live in 46383 indiana
