Front suspension rebuild kit
es1758
6:48 PM
Kansas city
Looking for suggestions/opinons on a front suspension rebuild kits and tubular control arms. Where to buy and to go back with the moog or to a poly set? Thanks
Most will say rubber. Tubular lowers and uppers? Uppers most replace with tubular. Mancini sells a Moog set. I'm planning on beefing up the tie rods with c body tie rods and adjusters. Check out firm feels stuff. Kinda leaning that way.
Tublar uppers only sorry, thanks for the input Ill check em out
and stiffening plates for the lowers
Why not polyurethane?
People say it beats the hell out of you and the car, but I have poly bushings in my Chevelle and think it feels fine. :shruggy:
On my Charger I went with the right stuff front end rebuild kit (rubber) from summit and tracked down Poly lower control arm bushings since they see probably the most wear out of any of them.
FYI for anyone buying the full poly sets, read carefully because none of the sets I saw came with lower control arm bushings. Had to track them down separately, through Prothane if I remember correctly.
Thanks I seen the summit kits and they seemed pretty reasonable.
Yep they should work just fine :icon_thumleft: but I would still suggest using poly lower control arm bushings, chances are when you pull the old rubber ones and see how little is left of them you'll see why lol
