Help--for the ones that have done it
no462of12K
3:13 AM
savannah, ga.
Just changed over from points to electronic (1970 rr wiring system--in 67 gtx --question--how hard is it to get this thing dialed in--just want to pop through the carb--any help would be beter than where i am now----thought i would call on the mopar knowledge--and save me some headaches--help help help; :
are you 180 degrees out with the distrib?most common mistake when switching.
Put the engine on TDC on the compression stroke and see where your rotor is pointing....and go from there.
if it's not 180 out, make durn sure you're rotor's pointing to #1, when I converted mine, I had my distributor gear enough teeth off that I was pointing at #2 instead of #1
