Pinion Angle?
98 SNAKE EATER
2:06 PM
Orlando/NYC
Been having some bad vibes at speed and decel
'69 RR
TF-727 Trans
8-3/4" Rear
Stock Height Leafs
OEM Pinion Snubber
Pinion snubber has a ~2.5" gap and apparently just barely touches under acceleration (grease test)
New U-Joints and output shaft bushing.
As she sits (level ground), everything measures dead flat at 0* (tail shaft, drive shaft and rear), which is probably the source of my bad vibes
I've searched and it seems everyone has their own opinion on how much pinion angle should be run.
So before I go ordering shims, I figured I'd post up and ask.
The level gauge goes on the flat of the front of pinion cradle. Also a second one goes on the front of the balancer. You want a full tank of gas. Look for 2 degrees down. Order steel shims only from Mopar no cast aluminum chinese crap. Or you can use brass shim from mopar.
The MoPar suspension book says 5-7* down, but that's generally for racing. I suspect something milder like what snakeoil said will work good. Maybe Supershafts will chime in. He does it for a livin.
I tried it in all positions and the readings were the same (0*)
The pix were the only ones where the magnet would hold lol
I'm at about 3/4 tank, but I have a rear mounted battery and a trunk full of crap :eek:
Will I have any issues with the bolt length in the shim holes for 2*-3* shims?
I feel your pain! I too am having vibrations - and they're not "good vibrations".
Here' s the basic scoop. For starters you need to be able to draw a straight line between the output shaft and the pinion. In other words if the output shaft continued out of the tranny it should line right up with the pinion centerline as one shaft. Then to establish angle you just change the elevation of the pinion or output shaft without rotating either end around a horizontal axis. Also there should be no side to side deviation or angle. As far as how much angle I think 3-5 degrees is about right but whatever the ideal number is it should be equal from end to end. Now to accurately measure all this is where I am at.
Ok i actually have a vehicle i have to go over this on, however the measurement you're taking at the diff isn't the right area.
Take the measurement at the joint cap or across the yoke top to bottom.
Give me a few minutes and i'll get back to this with a couple pics.
You want the pin angle to eventually wind up at 0.0 when the car is under full load, so depending what the spring can and can't control is your adjustment for that.
Getting to 0.0 is not what most people are going to worry about, what they are going to worry about is enough adjustment to lose the vibration under load.
However being you have vibes at speed and decel im already thinking something else is the issue, the at speed isn't usually a angle, the decel can be though, we'll have to see.
If you do have 0.0 everywhere than you don't or won't have a angle related vibe.
BBS
How much of the drive shaft balancing does it have to do with vibration? I mean every big block vibrates but how much is too much? and if you suspect too much how much would balancing the drive shaft help? Then worry about pinion angle?
Say that 10 times fast lmao but seriously...
We had a grerat machine shop in Macon years ago that I always used for drive shafts. It was owned by two OLD dudes retired from the military and had served as Navy machinists. They always said that as long as the shaft was straight as an arrow, it didn't need balancing. They were onto something too because they were renowned all over the southeast for their drive line work. I had them make many a drive shaft for me and never had one problem. I'm not saying balancing ain't important, but them old dudes didn't seem to worry about it much.
All that hooha said, gettin back to pinion angle. I've always set my MoPars up at the recommended 5-7* pinion nose down like the MoPar suspension book says. Too much for the street? I never had a problem. Super stock springs or otherwise.
The fact is, ALL drive shafts that use u joints vibrate. EVERY single one. The trick is, getting that vibration OUT of the operating range you're going to be in.
If you have a shaft that isn't balanced or off a little it can vary what and where the vibration is.
Now RRR brought up a issue of being perfect, i am kinda a perfectionist with my shafts being below the allowed run out, and even if they are 0 on run out they could use balancing, some may not need it, but you don't know unless you check.
The idea of being perfectly straight and not having to be balanced is not true as i have seen millions of times after truing, straightening shafts to perfection.
The slip yokes, weld yokes are cast and then machined and like a block can have core shift, slips and weld yokes can have the same issues.
The shafts themselves sometimes have small imperfections and may not be perfectly round and cause balancing issues.
It is rare a shaft doesn't need balancing, but when i hear a shop say "as long as the shaft was straight as an arrow, it didn't need balancing" i quickly believe they do not have a balancing machine and 8 out of 10 times im right on that.
I have learned experimenting with shaft on my machine to balance shafts to a particular area truing them to tune the shaft to take no added welded on weights.
OK onto the Pinion angle issue made as simple as i can make it ..
Ok here we have the trans end of the shaft and angle
As you see i take the angle measurement off the joints cap, and we have 3.6 degrees
Now to the diff end
We have .6 at the Diff
We have 6.0 on the shaft
Now this is at rest as it should be, when the power is applied the diff will rotate up 4 degrees and also change the shafts angle 2 degrees and alleviate the working angle at the front under load.
At rest there is a 6.5 degree diff at the shaft, and 4 degree diff at the working ends
Underload we'll have nearly identical angles between the trans and diff, the slight lift of the housing will change the shaft angle around 1.5 to 2 degrees making it a 4 degree slope, alleviating the working angle also.
Now in cars we don't have the slope to worry about like that of a truck.
What you need to is adjust the pin at rest for the movement the diff will make, you can do 2 things with that, you can put it on a drive on lift and hold the car back and load it up and watch it and see how many degrees it moves, or you can take a jack and jack against the end yoke and see what you can move it to.
What it moves to underload is what you want to adjust for, you want to have underload no angle between the two.
Now this is for street car stuff, not performance stuff, when we add performance and the shaft speeds go beyond 5000 rpm we want 0.0 angle underload everywhere.
Joints aren't designed to oscillate at any angle really above 5000 rpms, by 5000 rpms you want to have less than 3 degrees anywhere.
This is something that has taken chassis builders a long time to understand and why cars always had vibes.
There was always misinformation about needing angles for some oscillation, for a TRUCK yes, working a large joint and heavy loads and huge tq loads, yes a working angle of some degree is important for a TRUCK.
NOT performance cars, race cars and especially BOATS, which is still a thickheaded issue with boat builders.
Most cars built today are using less and even no angles.
Hopefully that was easier to understand.
OK, so I just got her back on my level lift and measured again flat on the shaft and on both yoke cups using a short impact socket.
Both the DS and Pinion still measure out at 0* while the trans yoke measures in at ~.5* (probably since I burned off more than a 1/4 tank today)
Not much of a difference compared to the readings I got last night.
So if both the trans and rear are completely level as she sits, where do I go from here :confused:
go with a 4 dg shim , if you can mount the cam to look at the diff from the side you would see more detail
You can not tell anything this way. Eliminate the basics first.
1. Trans Mount sag.
2. Bad U Joint.
3. Differential noises.
4. Drive shaft issues.
5. Put car on lift carefully, remove tires, get a 4 foot piece of wood 1 inch in diameter. Put car in gear and listen carefully. You can have an axel problems. Place the wood against the rear and listen thru the housing for any wierd sounds.
6. Remove drive shaft and place in gear, listen for sounds.
Then look at shimming the rear. The drive shaft could be bent or out of balance. But need to eliminate these items first. don't assume any thing.
1. Trans Mount sag.
2. Bad U Joint.
1) Trans mount is solid, however, there appears to be a missing mount or brace at the rear of the tail shaft? (2 bolt holes near the rear seal)
2) Both U-Joints were replaced 5 weeks ago, but I had to replace the rear joint again earlier in the week.
3) No unusual diff noises (the brand new Strange 12-Bolt in my T/A made more noise than this thing)
4) The drive shaft passed the chalk test, so at the very least it's straight. The weight is still in place, but I can't know for sure if it's balanced until I take it to the drive line shop.
5) Did this on jack stands with the weight on the axles and used a stethoscope on the rear end housing. Nothing out of the ordinary and everything spun smooth as silk, however, since both the trans and rear appear to share the same center line, this wouldn't really tell me much about the pinion angle since it wasn't under load.
6) This I have yet to do, however, I did have the tail shaft bushing replaced a few days ago just to rule it out (had very little play)
All this said, regardless of how the balance of everything turns out, isn't the objective to get the pinion angle as straight as possible under load?
The video clearly shows the pinion going nose up way past the center line under acceleration (which is probably why I tore up the rear joint in a matter of weeks)
Also, I misspoke about the vibe on decel.
I get it while under acceleration and when trying to hold a steady high speed (on and off the gas with a light foot)
If I let off the gas completely, she'll coast to a stop rather smoothly.
Going by the link Ron posted, I was thinking about a 6* shim since they recommend between 5-7* for the stock leafs....
Too much?
I can't honestly see how much it is moving to say 6 is better than 4, it is moving and at rest its more in right area for being underload than the other way around.
From your description you are explaining a angle related vibration issue though
Yeah, it was hard to find a good mounting spot for the camera in front of the axle (it's actually clamped to the fuel pump inlet line)
Since it will be raining all week, I yanked the DS yesterday and dropped it off at the drive line shop to have it balanced.
Also having them install a pair of lubeless joints since my local suppliers didn't have them in stock.
Once I get it back, I'll remeasure everything and go from there.
Keep in mind the video shows the car with the timing pulled for pump gas.
With full advance on race gas, she'll probably bend it a little more.
