Drip rail mouldings same Plymouth/Dodge?
carcrazyguy
5:59 PM
Texas
Are the drip rail moulding on a 71-74 Plymouth Sat/RR the same as a 71-74 Charger?
71-72 Sat/RR are not the same as 71-72 Charger and the 73-74's are different than the 71-72's in Plymouth and Dodge also
71 Ply RH, RM, RP, RS w/o vinyl 3504832-3 w/vinyl 3504834-5
72 Ply RL, RH, RM, RP, RS w/o vinyl 3504832-3 w/vinyl 3504834-5
73-74 Ply RL RH RM RP w/o canopy vinyl 3749062-3 w/ 3749060-1
71-72 Charger WP SE Fastback 3612912-3
71 Charger WH,WM,WP 500,WS w/o vinyl 3612914-5 w/3612912-3
72 Charger WL, WH w/o vinyl 3612914-5 w/3612912-3
73 Charger WL, WH w/o canopy vinyl 3749068-9
73 Charger WP SE Fastback w/halo roof pkg. 3749068-9
73 Charger WP SE Fastback w/vinyl roof w/o halo pkg 1944-5JX9
74 Charger WL w/o canopy 3749068-9 w/canopy 3749070-1
74 Charger WH w/o canopy vinyl w/opera window 3749068-9
74 Charger WH w/canopy vinyl w/o opera window 3749070-1
74 Charger WH & WP SE Fastback w/full vinyl w/opera E524-5JX9
All models listed are 2 door models
Black listed for the colored 73 and 74 Charger ones but in 73 other colors than black where available
As was previously stated my information posted was documented and correct
71/2 Plymouth and 73/4 Charger are the same. 73/4 Plymouth and 71/2 Charger are the same. Also V-top is different than painted top.
So if I am reading the correctly on my phone. A 71 full vinyl top car would use....
3612912 and 3612913
So what about the windshield trim? Same/different for 71-74 Plymouth and Dodge?
Even though they have different part #'s I can't fine any difference between 71/2 Charger and 73/4 Satellite D/R moldings and have interchanged them several times over the years. Be sure you get the ones correct for your car, either V-top or painted top molding
where is the best place to purchase new ones?
from what you stated, I have a 72 Satellite 3/4 vinyl and would need 3504834-5...
m looking for them as well as the roof trim that transitions from vinyl to paint running across the roof above the 1/4 glass
To my knowledge, there are no reproductions drip rail mouldings available for any 71-74 B bodies. That only leaves NOS....
they must cost a fortune! Do you know where they sell them?
I have a set that someone took off the car Im redoing and they are like pretzels, maybe I should send them somewhere for repair
