Timken PN for inner axle seal? (8-3/4")
98 SNAKE EATER
12:38 AM
Orlando/NYC
My local VatoZone lists a bunch of different part numbers for inner axle seals on my '69 Road Runner with an 8-3/4" rear :icon_confused: (I thought there was only one size?)
Anyone have the correct universal or Timken PN?
Gaskets, Seals
Position Chrysler National C/R Fel-Pro
Axle inner seal 4796698 8695S 15460 ---
Axle outer seal 2404216 8704S 19000 ---
Axle flange, foam 2070933 see flange kit see flange kit 55032
Axle flange, shim 2881314 see flange kit see flange kit ---
Carrier gasket 1673367 --- --- RDS 65833
Pinion seal, 1-7/8 2931862 5126 18708 ---
Pinion seal, 1-3/4 2931862 7216 18912 ---
Pinion seal, 1-3/8 2931862 8515N 18708 ---
Yoke repair sleeve --- 99187 99187 ---
Thanks for the info :cool:
Question:
Would I be able to remove them using one of these?
My slide pullers are buried in my shed and I'd rather not go digging for them if I don't have to :eek:
Use the end of the axle just like a pry bar works great.
Yeah, that's how I usually pull the Ford seals, but thought it might not be as easy with the Chrysler rear since the seals are deep in the tubes rather than flush at the ends.
Anyways, I left the old seals in place until I finish breaking in the new gears.
When I change the oil next weekend, I'll replace the seals.
You have been busy...
Pinion questions, ride height questions, now this!
